From memory this has been discussed msny times here, suggest you search for info .
In a Positive Displacement Pump, NPSH varies as a function of flow determined by speed. Reducing the speed of the Positive Displacement Pump pump, reduces the NPSH. Suggest you contact the pump manufacturer.
Actually we'd like to relocate pump unit.
However for this old pump, the documentation is missing.
Of course for NPSHA and acceleration head we can calculate.
We still search for NPSHR value.
If anyone have experience of NPSHR with similar or close size of pump, this will be helpful.
Configure this system without relying on the suction dampener to reduce acceleration loss - all the dampener really does is to attenuate the pulsations to some extent, even when it does work well. At the least, get a triplex double acting to cut down acceleration loss. Cheapo duplex will almost surely get you into trouble with Operations Dept,unless you have plenty of NPSHa.
