In order to test the nozzles of sand filters (vertical cylinder vessel) we have to introduce water in the vessel at the specific operating flow rate, both ascendant and descendant way.
I really don't understand,
Acc. which standard is the vessel designed and what des. pressure.
Why do you want to test with a flowrate?
Why not pressure?
Have you ever tested the nozzles before? I have to prepare some sort of procedure of how to test the installed nozzles on a plate inside a filter vessel. The filter vessel is cylindrical. It's a possibility to test only using pressure but in this way how can I see which nozzle is damaged?
