A couple more ideas for ya.
I would clean both sides of the focus lens. Wipe down the threads of the lens, lens adapter, and adapter threads. Make sure you have the gaskets between the lens and adapter, and adapter and machine. Calibrate the sensor head, then cut some holes and squares.
I move in 1mm / 0.040" increments with the 7.5" lens. What I do is move down, down, down, until it can't cut anymore and then make note of that focal position. Next I go back to my original starting point then go up, up, up, until it doesn't cut. Make note of that position. The ideal focal setting for that material is right in the middle of those two end points.
Example: Starting at -0.060, next,-0.100,-0.140... and at -0.240" sparks and sputters.
Then -0.060, -0.020, 0.020,0.060... and sparks and sputters at +0.100"
I am not sure if I did the math right
but I think the center between -0.240" and 0.100" is -0.07".
That position would the work great for 0.190, and 0.125 AL.
P.S. I tried that, working for Amada, Great Machines, pretty good company. Private practice is way better.
