noobpressue
Agricultural
I'm in the cannabis industry in Washington state. We are using heat and pressure to make a chemical reaction possible in one of our products. Currently the time it takes is much too long and I believe it can be sped up by increased pressure. The current pressure is formed by expanding gasses in a closed glass jar that has about 110 to 120 degrees of heat applied to it that is causing the gas. If I could create more pressure within the jar I believe it would speed up my process.
Does anyone know of a solution that fits the following requirements:
Benchtop or smaller than industrial.
Less than $5000 (preferably less than $1500)
Fits at least 2 small 4 oz Kerr canning jars. (chamber would need to be at least 6 inches tall and 4 inches in diameter)
Creates a strong pressure, but one that is adjustable, to find the optimal pressure that won't break the jars.
Creates said strong pressure while maintaining a semi accurate temp of 110 to 120 degrees F.
Thanks for any responses
