Nonlinear analysis shell
Bezujov
10
I´m modeling a helical staircase with shell elements and, at some very specific points, using elastic analysis, I get quite high stresses.
Is there a way to perform plastic calculation so that it redistributes when a certain stress value is reached?
Thank you.
Hi Bezujov,
I was going to post a question on this exact thing! So I will share what I know so far, but looking for other's help.
You can define a material's nonlinear properties by clicking SEE ADVANCED OPTIONS under Material Define:
When defining your shell, you need to define the material as LAYERED SHELL:
For homogenous material like steel, just pick one layer and give it NONLINEAR properties for desired effects.
When you set up your Load Cases, make sure to set up a Non-Linear case like Non-Linear Static where you can also get Large Displacements.
Try this post,
Hope this helps,
