Wraith
- Feb 3, 2002
- 12
I have this application were I require a sleave over an inflatable device. The device is a Firestone Air picker.
This device inflates from a cylinder shape to a balloon shape.
The application I am using this device for is to pick up engine pistons from the sides by inflating the bladders one on each side of the piston and sqeezing the piston.
In test trials we ran 50000 cycles and the bladders did not show wear.
But when running in the machine the bladders did not last 1200 cycles.
From the damaged baldders in the machine we have noticed that all the bladders fail the same way by a small slice down the side of the bladder.
I would like to know if anyone has a material that can expand with this bladder and also be wear resistant,and cut resistant.
I really need help.
I really need help.
