Non-newtonian Pressure Drop 1
777gne
Now that I have my pressure drop spreadsheet all polished up I get thrown a curve ball; I got handed some rheology data for a several shear thinning fluids. I'm a little rusty with non-newtonian fluids. Here's what I think I know, I'm hoping someone can give me a nudge...
The data that I have is:
Shear Rate (y) in Sec^-1
Apparent Viscosity (n) in centipoise
% Soilds
Specific Gravity
Specific Heat
Thermal Conductivity
...and a legend that reads n = 30,210*y^-.6310
This is a good start - at least I can determine the apparent viscosity at a given shear rate. I don't know if I have enough information to calculate pressure drops in piping though(?)
I believe that I need the constant of proportionality, usually shown as K, or the shear stress so I can calculate K. Can anyone verify this? Is this something that the lab who did the rheology would be expected to have access to?
The pressure drop equation that I have is:
delta P = (3 * n + 1 / n)^n * (Q / pi * r^3)^n * (2 * L * K / r)
- Is there a way to determine K from the info that I do have?
- Is there another means of determining pressure drop using the info that I do have?
Look at the equation for apparant viscosity above:
[ν] = k[γ]n-1 or k = [ν]/([γ]n-1)
The units of [ν] are cP.
The units of [γ] are 1/sec
The units of 1/[γ] are sec
Therefore the units of k are cP.sec(n-1)
Good luck,
Latexman
I collected enough references to derive what I was looking for in the other thread, but before I could do the derivation I thought of a different approach and just filed the information "for a rainy day".
Good luck,
Latexman
Whoa, you snuck a few posts in up there that I just saw.
I'm working in English units. The only reference material I have on this subject is in SI units.
v = Pa.s
K = Pa.sn
