JeremiahVanderlaan
I am having an issue with a non-linear analysis regarding compression resistance.
I am performing a non-linear buckling analysis for a steel truss, with a wind uplift which will result in the bottom chord of the truss in compression. Intuitively, the bottom chord will be the member to buckle as it is long and slender and in compression.
I have placed Interacting P-M2-M3 hinges at three places along the center bottom chord (Relative locations of 0, 0.5 and 1). The hinge should activate whenever the compression force, Cf, is greater than the compression resistance, Cr, in the bottom chord and attempt to redistribute the stresses elsewhere.
But what I am noticing is that the hinge is not doing anything until the stress in the bottom chord reaches the yield stress. Which is correct if the hinge was looking for tension, but since compression resistance takes into account the unbraced length of the member, Cr < Tr, meaning that the stress at a compression failure can be much less than the yield stress.
So, I realize that a compression failure is due to Euler Buckling, and it is not plastic deformation, and that is most likely why the hinge is not doing what I want it to do (Redistribute forces when Cf > Cr). Does anyone have experience with something like this and can suggest a way to get what I want?
Thanks!
Thanks!
