Non-convergence with yield strength and tangent modulus..
imse
Industrial
Feb 2, 2006
21
hi,
I am doing a simulation of Submerged arc welding... using decoupled thermo-mechanical analysis...
I obtained the pretty consistent transient temperature distribution (except for the first set of temperature distribution - probably due to the fact that welding begins at the corner of the plate). This part of the analysis uses temperature dependent conductivity and specific heat; constant density (no enthalpy)
Using the transient temperature result from the thermal analysis I attempted the calculation of stress and distortion with Young’s modulus (constant for now), possions ratio and thermal expansion coefficient (constant for now). I was able to perform a complete transient analysis.
But with the introduction of Yield strength and tangent modulus through bilinear plasticity function in material properties, the solution couldn’t converge - even on the first step. i have tried applying of Newton-ralphson (full) and arc step function
I am hoping to get the final distortion after the completion of welding... i am open to using other methods to obtain plastic deformation or distortions...
Could someone please advice!
Thanx
Robin
How are you performing your sub-steps for the non-linear structural analysis? An input file / log file for your solution processor would be helpful.
Symmetric half of a Weld plate 18"*3"*3/8"; heat input: heat flux 1.05e8; convection from some surfaces for now.... temperature in Kelvin and properties are in SI units
/PREP7
ET,1,SOLID70
MPTEMP,,,,,,,,
MPTEMP,1,273.15
MPTEMP,2,373.15
MPTEMP,3,473.15
MPTEMP,4,573.15
MPTEMP,5,673.15
MPTEMP,6,773.15
MPTEMP,7,873.15
MPTEMP,8,973.15
MPTEMP,9,1073.15
MPTEMP,10,1273.15
MPTEMP,11,1473.15
MPTEMP,12,1773.15
MPTEMP,13,2073.15
MPDATA,KXX,1,,51.9
MPDATA,KXX,1,,51.1
MPDATA,KXX,1,,49
MPDATA,KXX,1,,46
MPDATA,KXX,1,,42.7
MPDATA,KXX,1,,39.4
MPDATA,KXX,1,,35.6
MPDATA,KXX,1,,31.8
MPDATA,KXX,1,,26
MPDATA,KXX,1,,27.2
MPDATA,KXX,1,,29.7
MPDATA,KXX,1,,35
MPDATA,KXX,1,,41.5
MPTEMP,,,,,,,,
MPTEMP,1,323.15
MPTEMP,2,373.15
MPTEMP,3,423.15
MPTEMP,4,473.15
MPTEMP,5,523.15
MPTEMP,6,573.15
MPTEMP,7,623.15
MPTEMP,8,673.15
MPTEMP,9,723.15
MPTEMP,10,773.15
MPTEMP,11,823.15
MPTEMP,12,873.15
MPTEMP,13,923.15
MPTEMP,14,973.15
MPTEMP,15,1023.15
MPTEMP,16,1073.15
MPTEMP,17,1773.15
MPDE,C,1
MPDATA,C,1,,486
MPDATA,C,1,,486
MPDATA,C,1,,5519
MPDATA,C,1,,532
MPDATA,C,1,,557
MPDATA,C,1,,574
MPDATA,C,1,,599
MPDATA,C,1,,599
MPDATA,C,1,,662
MPDATA,C,1,,662
MPDATA,C,1,,749
MPDATA,C,1,,749
MPDATA,C,1,,846
MPDATA,C,1,,1432
MPDATA,C,1,,950
MPDATA,C,1,,950
MPDATA,C,1,,950
MPTEMP,,,,,,,,
MPTEMP,1,0
MPDATA,DENS,1,,7859
BLOCK,0,.46,0,.0095,0,-.076,
! /VIEW,1,1,1,1
! /ANG,1
! /REP,FAST
wpstyle,0.0095,0.1,-1,1,0.003,0,0,,5
wpof,,0.009500
wpro,30.000000,,
wpro,-30.000000,,
wpro,,,30.000000
wpro,,,-30.000000
wpro,,30.000000,
wpro,,-30.000000,
wpro,,-30.000000,
wpro,,-30.000000,
wpro,,-30.000000,
wpstyle,0.004,0.1,-1,1,0.004,0,0,,5
wpof,0.005000
CYLIND,.0050, ,0,.001,0,180,
WPSTYLE,,,,,,,,0
FLST,2,2,6,ORDE,2
FITEM,2,1
FITEM,2,-2
VGLUE,P51X
ESIZE,0.01,0,
MSHKEY,0
MSHAPE,1,3d
FLST,5,2,6,ORDE,2
FITEM,5,3
FITEM,5,-4
CM,_Y,VOLU
VSEL, , , ,P51X
CM,_Y1,VOLU
CHKMSH,'VOLU'
CMSEL,S,_Y
VMESH,_Y1
CMDELE,_Y
CMDELE,_Y1
CMDELE,_Y2
ALLSEL, ALL
TUNIF, 294
!**************TRANSIENT TEMP ANALYSIS*******************
FLST,2,2,6,ORDE,2
FITEM,2,3
FITEM,2,-4
VCLEAR,P51X
FLST,2,2,6,ORDE,2
FITEM,2,3
FITEM,2,-4
VCLEAR,P51X
FLST,3,1,6,ORDE,1
FITEM,3,3
VGEN,42,P51X, , ,.01, , , ,0
FLST,2,43,6,ORDE,2
FITEM,2,1
FITEM,2,-43
VGLUE,P51X
MSHKEY,0
MSHAPE,1,3d
FLST,5,43,6,ORDE,3
FITEM,5,1
FITEM,5,44
FITEM,5,-85
CM,_Y,VOLU
VSEL, , , ,P51X
CM,_Y1,VOLU
CHKMSH,'VOLU'
CMSEL,S,_Y
VMESH,_Y1
CMDELE,_Y
CMDELE,_Y1
CMDELE,_Y2
FINISH
/SOL
ANTYPE,4
TRNOPT,FULL
LUMPM,0
FLST,2,2,5,ORDE,2
FITEM,2,1
FITEM,2,6
/GO
SFA,P51X,1,CONV,25,294
ALLSEL,ALL
FLST,2,1540,1,ORDE,2
FITEM,2,1
FITEM,2,-1540
IC,P51X,TEMP,294,
FLST,2,1,5,ORDE,1
FITEM,2,218
/GO
SFA,P51X,1,HFLUX,1.05e8
OUTRES,ALL,ALL,
TIME,1.25
AUTOTS,-1
DELTIM,1.25,0.001, ,1
KBC,0
TSRES,ERASE
LSWRITE,1,
FLST,2,1,5,ORDE,1
FITEM,2,218
SFADELE,P51X,1,HFLUX
FLST,2,1,5,ORDE,1
FITEM,2,2
/GO
TIME,2.5
AUTOTS,-1
KBC,0
TSRES,ERASE
LSWRITE,2,
FLST,2,1,5,ORDE,1
FITEM,2,2
FLST,2,1,5,ORDE,1
FITEM,2,221
/GO
TIME,3.75
AUTOTS,-1
KBC,0
TSRES,ERASE
LSWRITE,3,
FLST,2,1,5,ORDE,1
FITEM,2,221
FLST,2,1,5,ORDE,1
FITEM,2,225
/GO
TIME,5
AUTOTS,-1
KBC,0
TSRES,ERASE
LSWRITE,4,
FLST,2,1,5,ORDE,1
FITEM,2,225
FLST,2,1,5,ORDE,1
FITEM,2,229
/GO
TIME,6.25
AUTOTS,-1
KBC,0
TSRES,ERASE
LSWRITE,5,
FLST,2,1,5,ORDE,1
FITEM,2,229
FLST,2,1,5,ORDE,1
FITEM,2,233
/GO
TIME,7.5
AUTOTS,-1
KBC,0
TSRES,ERASE
LSWRITE,6,
FLST,2,1,5,ORDE,1
FITEM,2,233
FLST,2,1,5,ORDE,1
FITEM,2,237
/GO
TIME,8.75
AUTOTS,-1
KBC,0
TSRES,ERASE
LSWRITE,7,
FLST,2,1,5,ORDE,1
FITEM,2,237
FLST,2,1,5,ORDE,1
FITEM,2,241
/GO
TIME,10
AUTOTS,-1
KBC,0
TSRES,ERASE
LSWRITE,8,
FLST,2,1,5,ORDE,1
FITEM,2,241
FLST,2,1,5,ORDE,1
FITEM,2,245
/GO
TIME,11.25
AUTOTS,-1
KBC,0
TSRES,ERASE
LSWRITE,9,
FLST,2,1,5,ORDE,1
FITEM,2,245
FLST,2,1,5,ORDE,1
FITEM,2,249
/GO
TIME,12.5
AUTOTS,-1
KBC,0
TSRES,ERASE
LSWRITE,10,
FLST,2,1,5,ORDE,1
FITEM,2,249
FLST,2,1,5,ORDE,1
FITEM,2,253
/GO
TIME,13.75
AUTOTS,-1
KBC,0
TSRES,ERASE
LSWRITE,11,
FLST,2,1,5,ORDE,1
FITEM,2,253
FLST,2,1,5,ORDE,1
FITEM,2,257
/GO
TIME,15
AUTOTS,-1
KBC,0
TSRES,ERASE
LSWRITE,12,
FLST,2,1,5,ORDE,1
FITEM,2,257
FLST,2,1,5,ORDE,1
FITEM,2,261
/GO
TIME,16.25
AUTOTS,-1
KBC,0
TSRES,ERASE
LSWRITE,13,
FLST,2,1,5,ORDE,1
FITEM,2,261
FLST,2,1,5,ORDE,1
FITEM,2,265
/GO
TIME,17.5
AUTOTS,-1
KBC,0
TSRES,ERASE
LSWRITE,14,
FLST,2,1,5,ORDE,1
FITEM,2,265
FLST,2,1,5,ORDE,1
FITEM,2,269
/GO
TIME,18.75
AUTOTS,-1
KBC,0
TSRES,ERASE
LSWRITE,15,
FLST,2,1,5,ORDE,1
FITEM,2,269
FLST,2,1,5,ORDE,1
FITEM,2,273
/GO
TIME,20
AUTOTS,-1
KBC,0
TSRES,ERASE
LSWRITE,16,
FLST,2,1,5,ORDE,1
FITEM,2,273
FLST,2,1,5,ORDE,1
FITEM,2,277
/GO
TIME,21.25
AUTOTS,-1
KBC,0
TSRES,ERASE
LSWRITE,17,
FLST,2,1,5,ORDE,1
FITEM,2,277
FLST,2,1,5,ORDE,1
FITEM,2,281
/GO
TIME,22.5
AUTOTS,-1
KBC,0
TSRES,ERASE
LSWRITE,18,
FLST,2,1,5,ORDE,1
FITEM,2,281
FLST,2,1,5,ORDE,1
FITEM,2,285
/GO
TIME,23.75
AUTOTS,-1
KBC,0
TSRES,ERASE
LSWRITE,19,
FLST,2,1,5,ORDE,1
FITEM,2,285
FLST,2,1,5,ORDE,1
FITEM,2,289
/GO
TIME,25
AUTOTS,-1
KBC,0
TSRES,ERASE
LSWRITE,20,
FLST,2,1,5,ORDE,1
FITEM,2,289
TIME,150
AUTOTS,-1
KBC,0
TSRES,ERASE
LSWRITE,21,
!**************TRANSIENT Stress ANALYSIS*******************
/PREP7
ETCHG,TTS
FINISH
/SOL
LSCLEAR,ALL
MPTEMP,,,,,,,,
MPTEMP,1,0
MPDATA,EX,1,,2.1e11
MPDATA,PRXY,1,,.3
MPTEMP,,,,,,,,
MPTEMP,1,0
UIMP,1,REFT,,,
MPDATA,ALPX,1,,11.1e-6
TBDE,BKIN,1
TB,BISO,1,1,2,
TBTEMP,0
TBDATA,,250e6,4.8e9,,,,
ANTYPE,4
TRNOPT,FULL
LUMPM,0
ARCLEN,ON
DA, 382,SYMM
ALLSEL,ALL
TIME,1.25
AUTOTS,-1
DELTIM,1.25,.25, ,1
KBC,0
TSRES,ERASE
LDREAD,TEMP,,,1.25, ,'TRIAL_KELVIN_heatflux_1.05e8','rth',' '
LSWRITE,1,
LDREAD,TEMP,,,2.5, ,'TRIAL_KELVIN_heatflux_1.05e8','rth',' '
TIME,2.5
AUTOTS,-1
DELTIM,1.25,0.25, ,1
KBC,0
TSRES,ERASE
LSWRITE,2,
LDREAD,TEMP,,,3.75, ,'TRIAL_KELVIN_heatflux_1.05e8','rth',' '
TIME,3.75
AUTOTS,-1
KBC,0
TSRES,ERASE
LSWRITE,3,
LDREAD,TEMP,,,5, ,'TRIAL_KELVIN_heatflux_1.05e8','rth',' '
TIME,5
AUTOTS,-1
KBC,0
TSRES,ERASE
LSWRITE,4,
LDREAD,TEMP,,,6.25, ,'TRIAL_KELVIN_heatflux_1.05e8','rth',' '
TIME,6.25
AUTOTS,-1
KBC,0
TSRES,ERASE
LSWRITE,5,
LDREAD,TEMP,,,7.5, ,'TRIAL_KELVIN_heatflux_1.05e8','rth',' '
TIME,7.5
AUTOTS,-1
KBC,0
TSRES,ERASE
LSWRITE,6,
LDREAD,TEMP,,,8.75, ,'TRIAL_KELVIN_heatflux_1.05e8','rth',' '
TIME,8.75
AUTOTS,-1
KBC,0
TSRES,ERASE
LSWRITE,7,
LDREAD,TEMP,,,10, ,'TRIAL_KELVIN_heatflux_1.05e8','rth',' '
TIME,10
AUTOTS,-1
KBC,0
TSRES,ERASE
LSWRITE,8,
LDREAD,TEMP,,,11.25, ,'TRIAL_KELVIN_heatflux_1.05e8','rth',' '
TIME,11.25
AUTOTS,-1
KBC,0
TSRES,ERASE
LSWRITE,9,
LDREAD,TEMP,,,12.5, ,'TRIAL_KELVIN_heatflux_1.05e8','rth',' '
TIME,12.5
AUTOTS,-1
KBC,0
TSRES,ERASE
LSWRITE,10,
LDREAD,TEMP,,,13.75, ,'TRIAL_KELVIN_heatflux_1.05e8','rth',' '
TIME,13.75
AUTOTS,-1
KBC,0
TSRES,ERASE
LSWRITE,11,
LDREAD,TEMP,,,15, ,'TRIAL_KELVIN_heatflux_1.05e8','rth',' '
TIME,15
AUTOTS,-1
KBC,0
TSRES,ERASE
LSWRITE,12,
LDREAD,TEMP,,,16.25, ,'TRIAL_KELVIN_heatflux_1.05e8','rth',' '
TIME,16.25
AUTOTS,-1
KBC,0
TSRES,ERASE
LSWRITE,13,
LDREAD,TEMP,,,17.5, ,'TRIAL_KELVIN_heatflux_1.05e8','rth',' '
TIME,17.5
AUTOTS,-1
KBC,0
TSRES,ERASE
LSWRITE,14,
LDREAD,TEMP,,,18.75, ,'TRIAL_KELVIN_heatflux_1.05e8','rth',' '
TIME,18.75
AUTOTS,-1
KBC,0
TSRES,ERASE
LSWRITE,15,
LDREAD,TEMP,,,20, ,'TRIAL_KELVIN_heatflux_1.05e8','rth',' '
TIME,20
AUTOTS,-1
KBC,0
TSRES,ERASE
LSWRITE,16,
LDREAD,TEMP,,,21.25, ,'TRIAL_KELVIN_heatflux_1.05e8','rth',' '
TIME,21.25
AUTOTS,-1
KBC,0
TSRES,ERASE
LSWRITE,17,
LDREAD,TEMP,,,22.5, ,'TRIAL_KELVIN_heatflux_1.05e8','rth',' '
TIME,22.5
AUTOTS,-1
KBC,0
TSRES,ERASE
LSWRITE,18,
LDREAD,TEMP,,,23.75, ,'TRIAL_KELVIN_heatflux_1.05e8','rth',' '
TIME,23.75
AUTOTS,-1
KBC,0
TSRES,ERASE
LSWRITE,19,
LDREAD,TEMP,,,25, ,'TRIAL_KELVIN_heatflux_1.05e8','rth',' '
TIME,25
AUTOTS,-1
KBC,0
TSRES,ERASE
LSWRITE,20,
TIME,25
AUTOTS,-1
KBC,0
TSRES,ERASE
LSWRITE,20,
ARCLEN,OFF
LDREAD,TEMP,,,150, ,'TRIAL_KELVIN_heatflux_1.05e8','rth',' '
TIME,150
AUTOTS,-1
KBC,0
TSRES,ERASE
LSWRITE,21,
thank you
Robin
Is it just me or is this missing an lssolve command. Something to try - try performing just one analysis with only one structural load step and see if you can get convergence on the structural end of things.
Also, I would not use the arclen method - it's really mostly appropriate for non-linear buckling problems. I would use auto time-stepping and set a much smaller minimum time step for the structural analysis. In fact, have you tried the analysis with solcontrol,on?
Give these a try...
