non- conductive, high temp material options??
fastline12
Aerospace
Jan 27, 2011
306
We need to induction heat some small parts and due to the small cylindrical size, we are concerned of interaction of the fixture and heating coil. Obvious thought might be to use standard plastics but because the part is a copper alloy, heat transfer into the fixture will certainly occur so the material may have to endure up to 500F.
Does anyone have any thoughts on either unfounded induction coil interaction or an idea of material we could test that would not be affect by the work coil?
At a previous employer we used a material called celazole to manufacture some one-off high temperature non-ferrous components. Ceramic wasn't chosen at the time due to the shape required, but in retrospect the machine shop reckoned they might have done better with Macor than celazole.
There are lots of materials that should non-interacting with RF:
alumina, silicon carbide, quartz
TTFN
faq731-376
7ofakss
Good point - is this a radio frequency unit heater or a medium-frequency type of a few kHz up to a few tens of kHz?
