Hi everyone,
Has anyone got some experience of stopping ground borne noise transmission ?
I have a problem with a pump in a wet well which is transmitting noise to a dwelling some 50 yards away.
The noise is definitley coming through the ground as you can hear it in the walls. It is a problem as the nightime noise level is less than 18 dBA in the bedroom and at the problem frequencies we see a rise of 5 to 10 db depending on ground conditions (wet or dry).
The problem frequency is approx 300 Hz which is 6X the blade passing frequency of the pump (2 blades). There is also a lower harmonic at 150 Hz which is very apparent.
It has been suggested that this is a mechanical vibration problem, but I am not sure as the frequencies are quite high. If it is just a mechanical phenomenom we could fit anti-vib mounts, but would solve the problem at the frequencies we are seeing.
Any comments would be appreciated ?
