No2 Diesel fuel Pump
piestro
5
Hi
Im designing a reagent area with No2 Diesel fuel. I m considering use a gear pump for pump diesel. The flow is around 8.9 gal per hour .This pump is suitable for the process or which pump can I use for No2 Diesel fuel?.
Thanks in advance
A gear pump is suitable for that application. For a flow that low, you might want to consider a diaphragm pump like those used as chemical metering pumps.
rmw
