I have a surface composition reading (analysis using SEM EDX) for a thin steel plate which I expected to be a plain carbon or spring steel, such as CS70/1070. The results are showing no manganese to be present. I would expect to see a Mn reading for all plain carbon steels as Mn is always added to scavenge residual sulphur in the steel, so to prevent grain boundary embrittlement. I would also expect the EDX technique to pick up a Mn reading. The sample surface was ground, polished, etched and cleaned prior to examination under vacuum.
Has anyone come across a plain medium to high carbon steel with no manganese before, or had problems with the EDX technique in this way?
Many thanks in advance for your help.
