Dear all,
I truly need your support on this nightmare.
I just had a huge argument with my boss, about something we are doubting so far.
Our client is currently asking for our support to determine the diameter of our pipe that is sufficient enough to have a total of flowrate of 86.4 m3/s.
So the pipe will be under the sea, conecting from the sea (which is in the right side) to a basin/ reservoid (left side). Because our pipe is just like a communicating vessel, the sea level between the sea itself and the reservoir will always remain the same. And from the reservoir it will be connected to a pump that will suck 86.4 m3/s water to the system. The client is requesting that the head loss due to friction shall always remain not bigger than 1.1 meter k =0.6
So the client is asking us to provide 4 lines (2 lines which is bigger than the 2 other lines), so that it can reduce the transportation cost by nesting it (putting the smaller diameter into the bigger one).
Now this is the funniest thing.
each line has different of length.
Line A 1616 meter
Line B 1604 meter
Line C 1601 meter
Line D 1613 meter.
Both me and my boss do a calculation comes up with 2 different result:
My boss argument is that:
- The head loss shall always be the same as the sea level of the reservoir and the sea intake are the same, which is 1.1 meter. (Does the head loss has anyting to do with the sea level??????)
- when the pump is activated to take the water from the reservoir, the velocity from each pipe can be different due to the length of the pipe (is this true??? I cannot imagine how the pump is possible to arrange different of velocity for each line).
and this is his calculation
he ends up having a combination of 4000 mm and 3500 mm diameter
My argument is:
The head loss cannot be the same as the length are also different. at the end the client is requesting that the head loss shall be smaller or equal than 1.1 meter. not all of them suppose to be 1.1 meter.
The velocity is the main criteria and shall always remain the same. . Is my argument correct?
I end up having a combination of 4000 mm and 3600 diameter.
What is the best argument for me to inform my boss about this?
Any idea??
Thank you so much for your full support. I add the excel sheet that my boss had done, and I made some adjustment.
Please review.
Line A 1616 meter
Line B 1604 meter
Line C 1601 meter
Line D 1613 meter.
My argument is:
Any idea??
Please review.
