Nickel Aluminium Bronze and Inconel
apf
GB
Would there be any reasons not to use nickel aluminium bronze and inconel in the same environment.
In what sense: electrically connected? What environment? Coupled in seawater, the NAB will be the anode and will suffer enhanced corrosion. How much depends on many additional factors.
Steve Jones
Materials & Corrosion Engineer
NAB has pretty good corrosion resistance, but a couple with 625 would drive selective dealloying. If they are not coupled it should be fine.
Plymouth Tube
They would be coupled together to form a valve body and seal and would be in contact with seawater.
We normally would be using Monel 400 but have no stock. We need to find a replacement material fast and have 625 in stock.
I would not suggest that 625 has good enough crevice corrosion resistance for a seawater valve seat. Try looking for one of "C" type alloys.
Plymouth Tube
