1
- #1
I did some experiments on Newtonian and non-Newtonian fluids measuring the pressure drop through a horizontal pipeline. The Newtonian two-phase flow was water+air and the non-Newtonian was (water+xanthan gum)+air.
I prepared 2 samples (2 concentrations) of the xanthan gum solution 1g/1L (995 kg/m3) and 2g/1L (990 kg/m3). I am wondering if it is logical that the Newtonian pressure drop was bigger than the non-Newtonian one?! Also the 2g/1L sample should've been with a higher density comparing to the 1g/1L!
