Newsgroup, mailing list or discussion forum on pressure vessels
  • Thread starter Thread starter -
  • Start date Start date
Guest
Is there any newsgroup, on-line discussion forum or mailing list regarding pressure vessels design?
Thanks in advanced.
Dick Chew
Pressure vessels design engineer
In this site you may try the forum ASME (mechanical).
Otherwise at there is a Pressure Vessel and Piping forum (password protected).
prex
motori@xcalcsREMOVE.com
Online tools for structural design
I cant find forum ASME under mechanical engineer.
Look in the Related Forums small window on the right of this screen: the forum is called 'ASME (mechanical)'
prex
You might also try although this forum tends to be limited to the pressure vessel design software of this company.
i would suggest we make use of the Valve Engineering forum itself to discuss on Pressure Vessel issues also. i tend to raise issues related to pressure vessels there itself, since valves and pressure vessel issues are more closely related. i invite all those with similar interests to kindly share your views in that forum.
