I'm trying to create a counterbore hole but wild fire will only let me make a threaded counterbore hole. How can I make a standard counterbore hole using the hole feature?
Change your hole type in the drop down box from simple to sketched, then draw the hole profile as if it was a revolve (all entities on same side of centerline). You can also save the sketch to use later.
