newbie counterbore question 2
snydergj
Aerospace
I'm trying to create a counterbore hole but wild fire will only let me make a threaded counterbore hole. How can I make a standard counterbore hole using the hole feature?
Change your hole type in the drop down box from simple to sketched, then draw the hole profile as if it was a revolve (all entities on same side of centerline). You can also save the sketch to use later.
MM
In the THREADED section, pick the option CLEARANCE HOLE. Now you can make a hole with a counterbore.
To change the Pro/E default clearance hole diameter, pick
"hole_diamter_override" to "yes" in your config.pro.
Steve
