I think it is not very useful to record a journal to edit feature dimensions and then somehow make this journal useful. It is simpler to write the code. Below is a fairly simple program to edit the feature expressions.
Option Strict Off
Imports System
Imports NXOpen
Imports NXOpen.UF
Imports NXOpenUI
Imports NXOpen.Features
Imports NXOpen.Utilities
Module EditFeature1
Dim theSession As Session = Session.GetSession()
Dim ufs As UFSession = UFSession.GetUFSession()
Dim ui As UI = UI.GetUI()
Sub Main()
Dim response As Selection.Response
Dim feat As Feature = Nothing
Dim exp As Expression = Nothing
Dim noExps As Integer = Nothing
Dim expdescstrings(-1) As String
Dim exptags(-1) As Tag
Dim expValue As String
Dim expTitle As String
Dim expvaluenew As Double
Dim nErrs1 As Integer
Dim id1 As Session.UndoMarkId
Start1:
response = select_feature(feat)
If response = Selection.Response.Cancel Then GoTo End1
ufs.Modl.AskExpDescOfFeat(feat.Tag, noExps, expdescstrings, _
exptags)
For i As Integer = 0 To noExps - 1
exp = NXObjectManager.Get(exptags(i))
expValue = exp.RightHandSide
expTitle = exp.Name
Try
expvaluenew = NXInputBox.GetInputNumber("Enter Exp Value", _
expTitle & " = " & expValue, _
expValue.ToString)
exp.RightHandSide = expvaluenew.ToString
Catch ex As Exception
GoTo Continue1
End Try
Next
Continue1:
nErrs1 = theSession.UpdateManager.DoUpdate(id1)
GoTo Start1
End1:
End Sub
Public Function select_feature(ByRef feat As Feature) As Selection.Response
Dim selobj As NXObject = Nothing
Dim cursor As Point3d
Dim typeArray() As Selection.SelectionType = _
{Selection.SelectionType.Features}
Dim resp As Selection.Response = _
ui.SelectionManager.SelectObject("Select feature", _
"Select feature", Selection.SelectionScope.WorkPart, _
False, typeArray, selobj, cursor)
If ((resp = Selection.Response.ObjectSelected) _
OrElse (resp = Selection.Response.ObjectSelectedByName)) Then
feat = CType(selobj, Feature)
Return Selection.Response.Ok
Else
Return Selection.Response.Cancel
End If
End Function
End Module
Hope this helps
Frank Swinkels
