New Spaceball Add-in
SBaugh
There is a new add-in for spaceball users - Fix: stop add-in from disabling the setting "dynamic highlighting of edges" when the first document is loaded.
I just downloaded it myself and I'm getting ready to test it. I hope it fixes it - Getting tired of having to go into Tools\options and resetting it all the time.
Scott Baugh, CSWP [elephant2][worm]
3DVision Technologies
faq731-376
When in doubt, always check the help
There was a ton of discussion a while back about SEVERE performance problems with Spaceball/SW 2003 after the initial release of 2003 . I am assuming this has been fixed? I have not seen any comment to that effect, so I assumed it was still an on-going issue. (Have a SpBl at home, but have not bothered to load it on my new machine due to the posts on the speed issue.) Ya see, I do listen and take note of all the comments ;-)
I run my SpBl on my system and I don't have any slow downs with it. I just had the beef with it turning that option off randomly. You should at least install it and judge for yourself, because you may not have an issue like everyone else is describing. Everyone's system is differnet and installed differently.
faq731-376
