New PE Needs Advice
CivilPE22
I work for a smaller consulting firm. I have worked under a PE with 40 plus years of experience for the past five years as an EIT. I received my PE license about two months ago and will be stamping my first project in the next month.
The PE under which I trained directed me to use “old school” methods in analyzing and designing structures on the basis that a more conservative design would result. I used these methods for the past five years in analyzing and designing structures. As a new PE my designs will still be subject to review by this senior PE. I have decided to basically consider both the out dated methods taught to me as an EIT, and ACI 350-08 and let the most conservative criteria prevail.
While designing my first project using this new approach, I discovered a significant difference in calculations between the two methods. I researched older codes and determined that certain provisions had been misapplied in the methods I was taught as an EIT. The result of the “old school” methods I was taught and the misapplication of certain provisions results in a less conservative design than the methods described in ACI 350 – 08. In some instances, some portions of the structure need to be twice as thick.
The fact of the matter is, there are many, many, structures that have been designed and passed the test of time under the “ old-school “ design methods I was taught as and EIT. However, I feel that I cannot place my stamp on something that’s designed under these methods.
I would like some advice on how I should approach the senior PE with this issue. I thought about going ahead and pushing the project through drafting and simply handing him the design; however, I know it won’t pass his smell test. He will immediately pick up on the differences and say I have been way too conservative. Since he does not want to learn the methods described in newer codes, I will have to take the older code that he has been working from for the past 40 years and show him how it has been miss-interpreted. I can also see him making the argument that there are literally dozens of these structures that have been designed under the same criteria and have withstood the test of time, which in my opinion has significant merit.
Any suggestions?
So did it turn out that you get to design the current way and stamp your own plans? How did he react besides just agreeing?
B+W Engineering and Design
Los Angeles Civil and Structural Engineering
I agree with Beej67, if he wants it his way he stamps it. Just mention what code you are using when you hand it to him for his review, so it doesn't look like you are trying to sneak one by him. If he doesn't want to you the most current code you can refuse to stamp it on basis of Engineering Ethics. You can always quote him some recent rules from the current Ethics Test you just took and passed.
He is not the one who has to worry about this for the next 40 years if your stamp is on it, he'll be long gone. If there is a problem 10 years from now, is he going to come out of retirement and defend your design?
3feet...an ethics test is not required nor given in all jurisdictions.
This was a great thread guys. Thank You. I too am a PE basically working under another PE and this thread has cleared up a lot of questions that I've had on reponsibility. Thank You.
beej67: I am laughing at that one. As true as that is, that's stepping on some toes. But this is a good point, maybe you just go in as a hard headed, we are now equal, don't question me anymore type of guy. Be ready to prove yourself though, if you can't ugh.
I saw how an old Project Manager treated those types of guys, it was not pretty at all. Be ready for anything.
Certainly. But by the same token, I've done quite a bit of stuff as an engineering subordinate that I wouldn't have stamped, or would have done differently if I had stamped, but didn't pitch a fit at all because it was someone else's stamp. If they're in responsible charge of the drawings, do it their way. Have an honest and open discussion of why you might do it differently if your own name was on the hook, but in the end it's their call how to do it, because it's their stamp.
Smile, shrug, "your stamp boss," got me through a lot of meetings in a former life.
Hydrology, Drainage Analysis, Flood Studies, and Complex Stormwater Litigation for Atlanta and the South East -
