For FRP we just call out either an equivalent reinforcement ("FRP equivalent to #4 @ 16"O.C."); so we can just design the new layout of walls with conventional reinforcement. Or you can do the change in capacity and call out the difference that the FRP will have to make up (e.g. your existing wall has a capacity of 5 klf and the new wall has a capacity of 2 klf, you would call out the FRP strength to be 3 klf). The latter is probably the most difficult and time consuming. I spoke to the FRP designers/manufacturers and they said I can just call out equivalent reinforcement. After I found that out, I started to do it that way, because it's easier (probably more conservative). However, I spoke to an old professor and he mentioned that FRP may be as strong as the steel reinforcement, but it is not as ductile, which led me to question using it for masonry shear walls and the reason I am looking for alternative ways to retrofit masonry.
