new material for a heat sink
Heft
GB
hi there
at the moment we use a copper chrome disk (concave and convex lens shaped) to transfer the heat from a cast iron base to a pyrex cap, the curvature of the cap and the base are different so the copper has a varying thickness.
what is happening is that the caps are cracking, and the coppers expansion is a consideration.
what im looking for are aternatives to the copper chrome, i need a high thermal conductivity and a low thermal expansion.
the caopper insert has at the moment a
COE = 18x10-6/degC
Thermal conductivity = 300w/m degC
any help would be greatly appereciated :)
Maybe use something softer than the copper, such as lead or heat-conductive putty. Might not stress the Pyrex as much.
Both are easy to form, so can make thinner than the copper to compensate for lower conductivity.
looks like you are generating a hot spot in the glass. in that case what you need is to reduce(not increase) the thermal contact.
basically use a lower conductiviy material than copper.
If the Pyrex cap is breaking due to thermal stress, switch to fused silica glass [it can withstand a quench from 850oC into icewater].
If the Pyrex cap is breaking due to mechanical stress, i.e., from the male copper part expanding inside a female cap, maybe you should change the design. Would a porcelein coating on the cast iron satisfy your requirements (chemical resistance? electrical insulator)?
thanks for the replies,
kenvlach, is fused sillica not quite expensive? and porcelin i have not thought about that. interesting
Metals: COE (ppm/C) TC (W/mK)
Molybdenum 5 150
Tungsten 5.5 200
copper-tungsten 8.5 210
copper-molybdenum 7.0 150
Ceramics:
aluminum nitride 4.6 190
silicon carbide 3 130
