CtrlSystemsEng
Chemical
I am installing an HMI in the door of a NEMA 4 enclosure. The panel will be located outdoors. Most of the NEMA 4 rated HMI's that I've come across are rated for indoor use only. I assume that sunlight glare and UV damage are the main reasons for limiting them to indoor.
Anyone have any experience or ideas on what the best, and lowest cost, solution would be for adapting this HMI for outdoor use without derating the enclosure? The HMI is pretty basic. Using it to start/stop a couple of motors and monitor some flowrates and pressures. I'm even thinking that monochrome will suffice. Thanks.
