Just to emphasize the point, a negative eigenvalue means that if the load were reversed, it would buckle at the applied load times the magnitude of the eigenvalue. But, the load must be reversed so if that is not one of the loads being considered then look for the lowest positive eigenvalue as the critical mode. You can try to force the eigensolver to only output positive values by setting the lower frequency range to a small number as well as the number of modes desired in the ND field on the EIGRL.
