Sam Burris
The Question:
-How would you go about automation the reciprocation of the hydraulic cylinder?
-How would you mechanically automate this system?
Context:
-I made a material piston pump that is powered with a hydraulic cylinder...
-The material pump needs to be on demand so I am using a variable flow pressure compensated piston pump to supply flow when needed.
Current Solution:
-I am currently using proximity sensors on either end of the stoke to sense when its time to switch direction
This will turn on or off a latching relay which powers a directional control solenoid valve.
The Problem:
-For the application this is a "fragile/ unreliable" control system (relay logic)
-And near impossible to diagnose when something is wrong (and I'm the one who designed it)
-Also the switching speed is slow (this is bad because the pump will stop for a second causing inconsistent pumping and hydraulic pressure spikes)
Question Recap:
Thanks for any input.
-Sam
Context:
Current Solution:
The Problem:
Question Recap:
-Sam
