Need urgent help..i am in mess..please help me to solve this problem 1
Sourab
AE
Hii frnds..problem cming at output side of delta ec3 plc (8inputs,8 outputs).
Output is not exciting relay coil.tested with micro relay also.same result.i have given +24v at output commons(source)..kindly tell me what should i do..
At output of plc,0v is coming instead of +24v bcz comm is positive.i changed the other end of coil but no result...
Kindly help me urgently..
Best regards!
 http://files.engineering.com/getfile.aspx?folder=98a3e739-b3ea-4d91-aa7c-5f7395e30a54&file=image.jpg
The internet is the worst place to go for FAST, RELIABLE help.
I suggest you contact the manufacturer or supplier of the Delta PLC.
