1. Your KC 850 is a coated insert. The only information given on the underlying carbide is “special”. If you identify the failure mode it will go a long way toward solving your problem. The failure mode can be in the coatings or in the carbide.
When I do carbide failure analysis I generally look at the part 17 different ways. See the information in the following link to see the different considerations.
2. The KC 850 is an old grade and there've been tremendous advances in carbide since Kennametal introduced it. However, since Kennametal never identified the underlying grade, it could be anything. Kennametal has a history of changing the compositions of their grades while still using the same identifiers.
3. There are some extremely tough new grades. Some of the old grades been greatly enhanced with modern technology. An example would be a 20% cobalt with some micron or nano grain technology. This ends up producing an extremely tough and extremely long wearing carbide part.
4. I have been following cryo technology for decades and would love to use it but so far it is neither predictable nor reliable. Anecdotal evidence indicates that when it works it can work extremely well however it may or may not work and there doesn't seem to be any way to predict that without actually using it.
If you like the idea of Cryo, then go ahead and try it. It doesn't seem to make things any worse.
Conclusion: We have quit using Kennametal for two reasons. 1. Their tech support is horrible. It is extremely difficult finding anyone who really knows anything. As mentioned above we have had projects going along swimmingly and then Kennametal change the composition of the grade without telling us causing the project to fail disastrously.
I would not place a lot of faith in cryogenics unless they could predict performance and guarantee consistent improvement. Every time we've asked about the reliability of the process, we have been told that they won't charge us if it doesn't work.
Thomas J. Walz
Carbide Processors, Inc.
Good engineering starts with a Grainger Catalog.
