RichLeimbach
I'm currently using a small (35mm can) motor to ramp a 2" dia x .5" wide flywheel from 0 to 15K RPM in ~ .5s. Because of the inefficiency of the motor at the low-end range, I am exploring both mechanical and electrical improvements to the current design. I belive that you can link to the motor discussion here:
I'm making this thread to see if anyone out there has a mechanical solution to the problem. What I'd like is a compact continuously varibale transmission design or a auto-shifting gear set-up. The main point is to increase efficiency in the low-end range of the ramp-up. I'm open to anything.
Any ideas?
Any ideas?
