Every gearbox that I've worked with in the past has been a reduction drive.
I haven't had the need (until now) to increase the RPM's from the motor shaft.
I need to move a screw (with a .2 lead) at the rate of 15 inches per second.
The Compumotor MPP1428Q41 meets my torque requirements if I can gear it up 1:3
Could I use the Boston Gear PL2142 Reduction Drive (3:1) in reverse to give me the 1:3 gear ratio?
