Need to add Thread callout to model and drafting
kkssandeep
AU
Hi All,
I want to add a note in the form of callout for threads in NX 8.5 model and import them to drafting.
In Pro/E it is possible to create notes in model.
Please provide me any solution whether I can add notes with leader in NX model.
Thanks in advance.
Sandeep
You can add dimensions, notes and symbols by using PMI. You can also display sketch dimensions as PMI's.
Later, you can 'call' those PMI dimensions on a drawing.
And if it is only a thread you are after, you can retrieve Thread definition on a drawing by using Feature Parameters command.
