I'm on a project to build a prototype, about 20"H x 10"W x 10"D.
It needs to compress powders into tablets about the size of an asprin tablet, which takes a minimum of 1/2 ton of compression pressure to accomplish.
I need some ideas on mechanisms that don't include hydraulics, but which will give the necessary compression at the compression point. It needs to be run via an electric motor.
I'm thinking of mechanisms along the lines of a worm gear or threaded means connected to the motor which will move a lever on a fulcrum back and forth which is connected to compression area. Any pulleys or gears in between to multiply the forces is fine, as long as it all fits within the dimensions mentioned.
Does anyone have any suggestions? Is there a known maximum mechanical pressure making mechanism already established so I don't need to re-invent given knowledge.
Many thanks beforehand!
