"Do not worry about your problems with mathematics, I assure you mine are far greater."
Albert Einstein
Have you read FAQ731-376 to make the best use of Eng-Tips Forums?
SQL is China's pressure vessel certification, similar to the AMSE coded vessels in the US. We have ASME certified relief valves, they have SQL certified relief valves. SQL is in the process of changing it's name to SELO.
Albert Einstein
