I have design a loop antenna with the maximum circumference is 19cm and 1cm width, which the profromance is not so good. So I want to get some news design. I will consider any type antenna. (the dimension with is 6cm x 2 cm X 1 cm.)
I need to design with a small antenna with high performance.
2. As it is close to a large LCD module which generate a EM Field which made the Antenna recvice not well.
Meanwhile it have not any headphone, so I cannot use headphone as antenna.
Please advice some FM broadcast antenna design.
Thank for your help.
