Hello all,
New to the forum and not an engineer, but work with them! I hope it's ok to have joined the forum and to ask this question here. If not please let me know.
I have recently installed a package heat pump unit on the roof of my building. Of course I was aware that there would be a noise issue, just not sure how much.
The roof is constructed of 3.25" x 14" glu-lam beams on about 6' centers, sheathed with 4.5" thick S.I.P.S. panels (3.5" EPS foam core with .5" OSB board glued to either side)
I built level curbs directly above two of the beams rising about 6" off the roof deck. I spanned between these two curbs with two beams constructed of three pressure treated 2x6s glued and screwed together. The package unit sits directly on these wooden beams.
My layman's intention was to try to transfer the vibration more directly to the beams as opposed to the rigid panel roof deck.
The reality is that the noise level inside is unacceptable. Bad on start up and shut down, and a constant strumming while the compressor is running, not so bad when it's just the fan motor running.
I have been researching vibration dampening mounts but thought it best to get some professional opinions before redesigning the mounting.
Would it help to to install some isolators between the beams and roof? Unit and beams? Both? What type? Should I build the beams of a different material?
Thank you in advance for any help you may be able to provide. My apologies if this is not the appropriate place to ask these questions.
Jonathan
Jonathan
