Hi All,
I need help in finding a seawater seal. I have a unique application where I have two filtered (to 10 microns) seawater filled chambers. A shaft turning at 3000 RPM runs between the two chambers. Chamber #1 will vary in pressure from ambient to 750 psi. Chamber #2 will have a pressure either equal or less than chamber #1, with minimum pressure in it being ambient. I need a seawater seal for the shaft going between the two chambers so that seawater doesn't flow between the two. Does anyone have a recommmendation for a seal that would do the job? And would anyone have a recommendaton on the shaft material? I'm assuming a Stainless Steel shaft would work well in this application, but anyone's experience would gladly be appreciated..
Gordon
Gordon
