Need Help NX Journal to set Attribute into parent program group 1
nxexplorer
ID
I need help in NX CAM, is there any sample on how to set Attribute into parent program group(.Net vbscript) without typing/filling the form.
What I want to add the attribute:
attribute name: CNC Operator
Value: Operator-1
Type:String
At the end of the journal running, there is the information verified in listing window:
"Operator-1 has been added as CNC Operator"
Somebody share any help with this case, I very much appreciate.
Maryadi
I have a recorded journal .vb from the customer site, that use NX10. The script as shown below:
Need guidance on how to modify it, so it will be able to be used as a command to create that attribute for other NX CAM sessions.
Option Strict Off
Imports System
Imports NXOpen
Module NXJournal
Sub Main (ByVal args() As String)
Dim theSession As NXOpen.Session = NXOpen.Session.GetSession()
Dim workPart As NXOpen.Part = theSession.Parts.Work
Dim displayPart As NXOpen.Part = theSession.Parts.Display
Dim markId1 As NXOpen.Session.UndoMarkId
markId1 = theSession.SetUndoMark(NXOpen.Session.MarkVisibility.Visible, "Edit PROGRAM")
Dim markId2 As NXOpen.Session.UndoMarkId
markId2 = theSession.SetUndoMark(NXOpen.Session.MarkVisibility.Invisible, "Start")
Dim nCGroup1 As NXOpen.CAM.NCGroup = CType(workPart.CAMSetup.CAMGroupCollection.FindObject("PROGRAM"), NXOpen.CAM.NCGroup)
Dim programOrderGroupBuilder1 As NXOpen.CAM.ProgramOrderGroupBuilder
programOrderGroupBuilder1 = workPart.CAMSetup.CAMGroupCollection.CreateProgramOrderGroupBuilder(nCGroup1)
theSession.SetUndoMarkName(markId2, "Program Dialog")
Dim taggedObject1 As NXOpen.TaggedObject
taggedObject1 = programOrderGroupBuilder1.StartUdeSet.UdeList.FindItem(0)
Dim taggedObject2 As NXOpen.TaggedObject
taggedObject2 = programOrderGroupBuilder1.StartUdeSet.UdeList.FindItem(1)
Dim taggedObject3 As NXOpen.TaggedObject
taggedObject3 = programOrderGroupBuilder1.StartUdeSet.UdeList.FindItem(2)
' Dialog Begin Program
programOrderGroupBuilder1.Destroy()
theSession.UndoToMark(markId2, Nothing)
theSession.DeleteUndoMark(markId2, Nothing)
theSession.UndoToMark(markId1, "Edit PROGRAM")
theSession.DeleteUndoMarksUpToMark(markId1, "Edit PROGRAM", False)
' Menu: Tools->Operation Navigator->Object->Properties
Dim markId3 As NXOpen.Session.UndoMarkId
markId3 = theSession.SetUndoMark(NXOpen.Session.MarkVisibility.Visible, "Start")
Dim objects1(0) As NXOpen.NXObject
objects1(0) = nCGroup1
Dim attributePropertiesBuilder1 As NXOpen.AttributePropertiesBuilder
attributePropertiesBuilder1 = theSession.AttributeManager.CreateAttributePropertiesBuilder(workPart, objects1, NXOpen.AttributePropertiesBuilder.OperationType.None)
attributePropertiesBuilder1.IsArray = False
attributePropertiesBuilder1.DataType = NXOpen.AttributePropertiesBaseBuilder.DataTypeOptions.String
attributePropertiesBuilder1.Units = "MilliMeter"
Dim objects2(0) As NXOpen.NXObject
objects2(0) = nCGroup1
Dim generalPropertiesBuilder1 As NXOpen.CAM.GeneralPropertiesBuilder
generalPropertiesBuilder1 = workPart.PropertiesManager.CreateGeneralCAMPropertiesBuilder(objects2)
generalPropertiesBuilder1.Name = "PROGRAM"
Dim objects3(0) As NXOpen.NXObject
objects3(0) = nCGroup1
attributePropertiesBuilder1.SetAttributeObjects(objects3)
theSession.SetUndoMarkName(markId3, "CAM Task Properties Dialog")
attributePropertiesBuilder1.Title = "CNCOPERATOR"
Dim markId4 As NXOpen.Session.UndoMarkId
markId4 = theSession.SetUndoMark(NXOpen.Session.MarkVisibility.Invisible, "CAM Task Properties")
attributePropertiesBuilder1.StringValue = "OPERATOR-1"
theSession.DeleteUndoMark(markId4, Nothing)
Dim markId5 As NXOpen.Session.UndoMarkId
markId5 = theSession.SetUndoMark(NXOpen.Session.MarkVisibility.Invisible, "CAM Task Properties")
Dim nXObject1 As NXOpen.NXObject
nXObject1 = attributePropertiesBuilder1.Commit()
Dim nXObject2 As NXOpen.NXObject
nXObject2 = generalPropertiesBuilder1.Commit()
Dim id1 As NXOpen.Session.UndoMarkId
id1 = theSession.GetNewestUndoMark(NXOpen.Session.MarkVisibility.Visible)
Dim nErrs1 As Integer
nErrs1 = theSession.UpdateManager.DoUpdate(id1)
theSession.DeleteUndoMark(markId5, Nothing)
theSession.SetUndoMarkName(id1, "CAM Task Properties")
attributePropertiesBuilder1.Destroy()
generalPropertiesBuilder1.Destroy()
' Menu: Tools->Journal->Stop Recording
End Sub
End Module
If I understand this code below can help you
Code:
Option Strict Off
Imports System
Imports NXOpen
Module NXJournal
        Dim lw As ListingWindow       = theSession.ListingWindow
        lw.Open()
        Dim Attributename As String = "CNC Operator"
        Dim Attributeval  As String = "Operator-1"
        Try
            nCGroup1.SetUserAttribute(Attributename, -1, Attributeval, Update.Option.Now)
            lw.Writeline(Attributeval & " has been added as " & Attributename)
        Catch ex As NXOpen.NXException
            lw.Writeline(ex.ToString())
        End Try
    End Sub
End Module
Hi UserCFAO,
Thank you for your help. The user has run this journal, and the error message is come out, as shown:
I think this because the Program Group Name is not "PROGRAM".
NXOpen.NXException: No object found with this name at NXOpen.CAM.NCGroupCollection.FindObject(String sid)
at NXJournal.Main(String[] args) in C:\Users\NCProgrammer1\AppData\Local\Temp\NXJournals7756\journal.vb:line 19
Best Regards,
Maryadi.
You are right
Try this
Code:
Option Strict Off
Imports System
Imports NXOpen
Imports NXOpen.UF
Imports NXOpen.Utilities
Module NXJournal
        Dim ufs As UFSession             = UFSession.GetUFSession()
        Dim theUI As UI                  = UI.GetUI()
        lw.Open()
        Dim selectedCount As Integer = 0
	Dim selectedTags As Tag()    = Nothing
        Dim type As Integer
        Dim subtype As Integer
        Try
            ufs.UiOnt.AskSelectedNodes(selectedCount, selectedTags)
            If selectedCount = 0 Then
                theUI.NXMessageBox.Show("Error : ", _
                                        NXMessageBox.DialogType.Error, _
                                        "No CAM node selected...exit")
                Exit Sub
            End If
            For i As Integer = 0 To selectedCount - 1
                ufs.Obj.AskTypeAndSubtype(selectedTags(i), type, subtype)
                If type = 121 Then 'Program group
                    Dim nCGroup1 As NXOpen.CAM.NCGroup = NXObjectManager.Get(selectedTags(i))
                    lw.Writeline(Attributeval & " has been added as " & Attributename & " in " & nCGroup1.name())
                End If
            Next
        End Try
    End Sub
End Module
Hi UserCFAO,
It is works perfect! That is what I hope. The main purpose from this journal as now, the user want to change UDE procedure with an attribute. Now I will guide them on how to connect it into post builder and OWI.
I very much appreciate yours with this sharing.
Maryadi
