Need help in finding metric O rings
Mech5656
Hello All,
I need to buy below O-rings for a project and I can’t find a supplier to buy them. Can you check these sizes/specs and let me know if I am missing something? What is so special about these O-rings?
350 x 5.7mm spliced and vulcanized EPDM 80 durometer o-ring
160mm x 5.7mm spliced and vulcanized EPDM 80 durometer o-ring
530mm x 5.7mm spliced and vulcanized EPDM 80 durometer o-ring
507mm x 5.7mm spliced and vulcanized EPDM 80 durometer o-ring
It could be one of 2 options
They can't supply the hardness you are asking for - you could ask what hardness they can supply
They can't supply the section.
There is one 'standard' size o-ring that could be used. Instead of 160mm, you could try to ask for a 159.30 (Size reference G160).
Thanks Robertib. Is 80 durometer O-ring not common? What about the bigger O-rings? Are they totally out of range? Can O-ring stock cord be supplied and we can cut and glue the o-ring? Is that reliable?
It appears that EPDM in any form at 80 durometer is not common.
Where did the 80 durometer requirement come from?
custom made O-ring
Where did you come up with these sizes and specs? Not from a readily available catalog, apparently.
Since they are all 5.7mm you could buy cord stock and make them.
Build a small jig so that you get exact miter cuts.
And a way to hold them aligned when you glue them.
I would hesitate to give the OP any advice about how to "make" custom o-rings without a better understanding of the application. Is it static or dynamic? Speed and direction? Pressure range? Media? Temperature? Critical application?
Or change the dimensions of the related part features so a standard o-ring will work.
