I need help creating Delta Angle Symbol in dimension text. You know that little triangle symbol. Is there a key command to make it like the degree symbol (Alt+248)?
I finally figured it out.. I went to Help in Autocad (2006 by the way) did a search on on Delta, and found a topic called "Symbols and Special Characters"
