sprintcar
- Oct 16, 2001
- 763
HELP!!
I need a spreadsheet (or formulas) to calculate and graph water flow thru an annulus formed by the gap between a circular orifice (square edged) surrounding a shaft. Variables will be water pressure, orifice ID, orifice thickness, and shaft OD. Temperature will be constant (probably 70F). I can dig thru Cameron’s but I figure somebody in our great group of Engineers probably already has one. (I’ll post this in a couple forums) THANKS!!
"If A equals success, then the formula is: A = X + Y + Z, X is work. Y is play. Z is keep your mouth shut."
-- by Albert Einstein
