platteriver
Computer
I paid a firm to design a gear pump for me and I am REALLY skeptical about the design. I am not a mechanical engineer and am hoping you guys could give me some basic input.
This is a very small gear pump similar to a chemical spray pump. It is running off of a 9.6v battery and a small motor with an RPM of 5700 under load at max efficiency. The motor shaft inserts thru the pump wall and directly into the drive gear
(pinion gear). No bushing. A lip seal is in place to prevent leaks. Neither the drive or the idler have any shaft, bushing, or other means of stabilization other than the recessed portion of the housing.Gear side housing uses a recessed o-ring to seal. The other half of the housing is completly flat. Whole thing is machined out of delrin
The gears are binding repeatedly and the drive gear is showing tremendous wear. Almost like grooves cut into it on a lathe.
Specific questions- shouldn't it have some sort of bushing or "peg " to hold the gears? or the drive shaft?
In similar designs I have seen the lip seal in place past the bushing, this one is simply around the shaft and fits into the bowl. Is this right?
Finally, the first submitted prototype didn't produce enough flow so they increased the size of the gears and the output port, but left the intake the exact same size. ?? This has to be a mistake right??
are there any resouces that detail design requirements and effects of gear pumps?
Thanks in advance for any help your community can provide.
