Need 1045 Tubing Stock
MASSEY
I am trying to locate 1045 tubing with OD's of 3"-14" with a variety of wall thicknesses.
I can find companies (LTV Copperweld for example) that will make it for me. However 4 month lead times and 5000' minimums are not an option.
Does anyone know where this tubing may be stocked?
Did you ask Copperweld which distributors they sell to? They may stock it.
You need to look at service centers or distributors, not tube manufacturers. Jorgensen would be my first choice-- lots of selection, and I know that 1045 is available as seamless tubes. Their website is
Other places to look, which include some large and small distributors:
Thanks for the tip on Jorg. they have 4 sizes in stock.
I've checked all kinds of distributors & service centers. Jorgensen is the only one I've found that stocks it. The other companies listed above do not. I know that tube manufacturers is a last resort, but I think I'm there.
I don't recall ever seeing 1045 as tube. I checked EMJ, Corus, and Castle's literature and none of them list it as a tube material. Does it have to be 1045? I would have thought the high carbon content would make 1045 undesireable for most applications other than shafting. Would 4140, which is readily available, work as well for your application?
4140 would work but it is costly compared to 1020, 1026 etc.
We currently use 1045 solid stock, bore out about 80% and cut threads for bolts around the perimeter.
I want to switch to tubing to save time and money but the threads strip out in low carbon tubing.
So I'm testing thread-forming taps - sizes over M14 are hard to find and expensive. I need holes up to M20. Additionally, some components are stress relieved so they don't distort when split. If I stress relieve a thread-formed hole I lose the benefit of thread-forming.
The easiest fix is to cut threads in 1045 tubing, but ...back to the top.???
