NDT performed after or before Hydrotest test
mrmalcolm
Marine/Ocean
CN
Dear colleagues,
Any code mentioned Non-destructive testing should be performed after or before the hydrostatic test?
If non-destructive testing is performed after the hydrostatic test, is it possible that the hydrostatic test could cause minor imperfection to expand into major defects?
If non-destructive testing is performed before the hydrostatic test, could the pressure of the hydrostatic test cause the pressure vessel to explode?
Thank you.
“To in sure weld integrity”. : INCORRECT
Pressure test is to check a pressure vessel integrity, not only the welds
Hydrostatic pressure test for piping is different for pressure vessels.
I think you lost it, better take a chill pill
Nitrogen leak test
After Cleaning fittingtack welding and welding atlas centaur oxygen and hydrozine fuel lines, a pressure test is conducted with helium. The welds do leak but it is very very light. Which then has to be repaired or reworked.
