Naval Shock Spec
varistor
16
Hi All,
I.m trying to track down a naval spec BR 3021. I think it is a uk naval spec but not sure where to source
Hi ISZ
I have tried the DEFSTAN site, but i can only find it referenced, unless of course it has been superceeded by a defstan
If you look under the "standards" tab, there is "defense standards". I did not use the search as one must be registered and I didn't want to mess with it.
ISZ
Yep still no luck, searched all of defstan site, no good
The numbering scheme doesn't match the DEF STAN scheme, so it's a British military standard, but not a DEF STAN. Oh, and note that there appears to be two volumes to the Shock Manual. Also, it appears to be superceded by BR 8470, not that it's any easier to find.
You might need to actually talk to someone at the British MOD
TTFN
FAQ731-376
