Natural Gas Pipe Seismically Exempt?
greggriffin
Is a natural gas pipe inside/outside a building allowed to be exempt from seismic bracing if it is less than 2-1/2" in interior diameter and/or mounted less than 12" from top of pipe to supporting structure?
In which US state is this building?
What is the design code for the pipe?
If its in a compressor station, probably not.
"Pumping accounts for 20% of the world’s energy used by electric motors and 25-50% of the total electrical energy usage in certain industrial facilities."-DOE statistic (Note: Make that 99% for pipeline companies)
I want to follow IBC 2006 regulations. In summary, 'Is a pipe used to transport high hazard material allowed to use either or neither of the 12" rule or small pipe size exemptions?'
I don't have that code. Maybe somebody else knows. Sorry.
You might try asking this question at Its specifically site for building code question forums.
