[apologies up front, it appears the photo link coding is not cooperating. For those bold enough to try the links, please repost them if both time and interest allow.]
This happens to be 4140 low alloy steel. The part imaged serves as the plug at the base of an isostatic press. The sealing surface is not shown, but is the surface opposite the large stain in the first two images.
This being the plug, it is at the bottom of the chamber barrel, and some process fluid [water, lubricant, and some anti-bacterial agent] tends to sit at whiles between cycles.
My wonder, [being the new guy with 'some' isopress experience] I would have expected them to use more lubricant. That said they have not seen such corrosion before. The machine was installed new in July 2013, and even just 1 month ago their was remarkably less corrosion evident.
