EidenC
- Aug 12, 2009
- 1
We have a customer that dimensions gussets welded to circular plates on a regular basis and we have come to an argument on their dimensioning scheme.
I have attached an example and am wondering if the 6X 60 Deg dimension for the 6 gussets is an accepted practice as the stack up doesn't make sense.
If a welder welded all of the gussets going around the plate at 60.5 Deg apart, he would be way out of tolerance when he welds the final gusset on. The dimension would be 57.5 Deg between the last gusset and the first.
-or-
Does this mean that the welder has to find all of the angles theoretically perfectly and he has +/- 30’ off that?
-or-
