multiheaded cable assembly
monkeysolder
Hello -
I am making some multiheaded cables - Basically a 10 pin connector at one end and about 7 different connectors on short lengths of cable branching out at the other end. They are small quantity so custom molding is probably out of the question.
Does anybody know of any way to effectively shrink tube the whole thing? Maybe some sort of multiheaded custom shrink tube? I am worried about the junction between the spliced on connector cables and the main cable being ugly and unreliable. All suggestions are welcome.
Thanks,
If it is underground and not pressurized it will be full of water. That's a given, not much you can do about it except slow down the water, but if you slow down the water coming in, you also slow down the water going out.
Keith - To answer your previous question, I work at a small gadget shop that makes playthings for high-end military customers ( ;
