When putting in a steel column on a floor higher than a basement, what is a typical detail to get a load path through the wood framed floor? For instance, if there is a beam supporting ceiling joists on a single-story house, a supporting column would have to be ~16' long (8 foot story height plus 8 foot basement height) to get to a footing. That seems impractical, so are 8 foot columns typically stacked? If so, what is a typical detail where they meet? A direct connection or is there blocking between them within the floor framing? Thanks!
